static void HelpMe(Args _args)
InventTrans _inventTrans;
InventDim _inventDim;
while select * from _inventTrans
join _inventDim
group by _inventTrans.ItemId ,_inventDim.InventColorID, _inventDim.InventSizeId,_inventDim.configId
where _inventDim.inventDimId == _inventTrans.inventDimId
print _inventTrans.ItemId + _inventDim.InventColorId + _inventDim.InventSizeId + _inventDim.configId;
Pause;
Working perfectly…
but
but below statement is giving error…
while select ItemId,_inventTrans.InventColorId,_inventTrans.InventSizeId,_inventTrans.ConfigId from _inventTrans
join _inventDim
Pause;
Your query is syntactically wrong - InventColorId, InventSizeId and ConfigId fields are defined in InventDim table and they have to be placed appropriately in the select statement:
while select ItemId from _inventTrans
**join InventColorId, InventSizeId, ConfigId from _inventDim**
Hi martin,
I am running into a similar problem with joins.
while select PersonnelNumber, RecId, Person from hcmWorker
join Worker, RecId, LegalEntity from hcmEmployment
where hcmWorker.RecId == hcmEmployment.Worker
//join hcmPersonPrivateDetails
//where hcmPersonPrivateDetails.Person == hcmWorker.Person
//join hcmPersonDetails
//where hcmPersonDetails.Person == hcmWorker.Person
// join Worker, SeniorityDate, OfficeLocation from hcmWorkerTitle
where hcmWorkerTitle.Worker == hcmWorker.RecId
join hcmEmploymentDetail
where hcmEmployment.RecId == hcmEmploymentDetail.Employment
&& hcmEmploymentDetail.WorkerStartDate >=_fromDateUtc
&& hcmEmploymentDetail.WorkerStartDate <_toDateUtc
When I run this query as it is - it works fine, but when I try to remove the ‘//’ it does not even enter here. What I am missing?
It may be related to invalid or missing data, but just want to make sure that the query is correct.
nath, it sounds to me like something unrelated to the problem discussed in this thread.
If I understand your problem, the query works, it just returns no data, because one of those joined tables has no related record.
