Dear Friends I need to print 4 copies of a Report when it is printed how can i do this. and also one text filed should change as “Original”,“Duplicate”,“Triplicate” and “Quadriplicate” How can i do this… Thanking U in Advance Prem
Hello, Use Interger Table with a range 1 to 4 In the trigger “OnAfterGetRecord” of the Interger table user a text variable, change the value of the variable when the value of interger change
You have an example in report 206 “Invoice” DataItem “CopyLoop”
Dear Fabrice I have two data items on that report i tried placing the integer dataitem as 3 and 1 when its One its displaying only the “Quadriplicate” text nothing else is comming… so how should i do this… how can i set the table range to 1 to 4 … Thanking U Prem
