Multiple Duplicate Line Numbers
We have an issue where our PO’s are duplicating LINES numbers on the PO. I am just wondering if there is a reason AX allows this assides from the “Rules” e.g. when the Line been fully recieved, or possibly Fully invoiced? Not after a solution per say here, just a reasoning.
Regards and Thank you.
There is an unique index on PO number and Line number, so there should not be any duplicate line numbers for a given purchase order.
Thanks for the reply Kranthi.
I agree However I do have examples that show we do have A PO with Line level and Numbers are:
1
2
2
2
3
4
5
6
6
Are you not getting the synchronization errors?
NO, there are no errors to be had, it looks like it is allowing it, just not sure why?
see if the index is enabled and is unique
can you write a job like Purchline purchline1,purchline2; int i; ; while select purchline1.lineAmount==purchline2.linelineAmount && purchline1.recID!=purchline2.recID { i++; purchline1.dodelete(); }
