Multilangauge Enabling a 2.60 database
hi i have translated the Spanish Version of NF-2.60 with the help of Translate (import/Export). All the code have been translated to english, but the names of the variables remains the same as that of Spanish Verison,due to which the objects are not being complied.The NF 2.60 database was opened in Attain 3.60 What i deed is selected all the object from the object designer and exported them with the help of Langauge (export ) from Standard English NF-2.60. Then i imported the file on the Spansih NF-2.60. This has translated the C/AL code but the global variables remains in spanish. Do i have to change the variable name manually. Is there any other way to Enable a database to multilanguage. Actually i am doing this to Upgrade it to 3.70 thanks
well. enabling multilanguage is settin caption m.l. and stuff. but what you try to do seems to translate the code itself. never done that before. but you could export the objects in text mode and change them there. most variables on objects use the same naming convention so it should be less work.
Why don’t you just start with the 3.70 Spanish version?
hi David, I actually want to upgrade my existing database of NF-2.60 to Attain 3.70. thanks
hi Have any one translated the Spanish NF-260 to English with Navision Localization Workbench. I am not able to get the translation database for NLW. If some one have it plz let me know. Regards
