well i have a small question, i created a new form wich contains a checkbox field, so for each row in my form i want that the user could check the current line , so is there a way to know after submitting the form which lines were checked.
Actually the user could either made the check or not so in the onPush trigger i would like to get wich lines in where the checkbox is selected , i made a first try with this code but it always rendered the last checked line:
string:=’’; // text var
IF check THEN BEGIN //chek is the src expression for my checkbox field , boolean var
string+= “Operation No.”;// concatinate the string var foreach checked row in the form
MESSAGE(‘the selected rows are:’+string)
END;
Why not just train the user how to mark records? Ctrl+F1. It even puts a dot to the left of the line to indicate that it is marked. Then you can do a MARKEDONLY and get the “checked” records.
Well, there’s no marking in the RTC, but you can still filter down to groups of records you want to process.
If you really wanted to do it with the Check Box, I would say add a “Checked” boolean field to the table, then build a form using temporary records. That way the user is not directly modifying “Checked” in the table, but instead only in their view.
