Hello, i’m looking for some examples of automation between MS-Project 98 and Navision Financials
Hi. You can automate Navision in MS-Project in 2 ways. 1.- Create instances to msproject application, resources, tasks, … 2.- Save Ms-Project in ODBC Driver (SQL Server, Oracle, Ms Access, …), and atack it directly with automation (Jet o OLE-DB).
Thanks for the tip. I’ve solved the problem by using automation. Now I can create a project within NF and copy all properties I need in MS Project.
