I want to import data from Access to Nav 2.6
Hi. You can read from Access with C/ODBC or write from Navision with ADO. Follow the link below and You see an example for reading from Access with ADO. It shouldn’t be so hard to modify it to write to Access instead http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=2745&SearchTerms=ADO //Lars
hi bobby, use automation variable “Microsoft ActiveX Data Objects 2.6 Library” in navision that will be easier then c/odbc you can read or write data with access.
