After going thru lot of docuemnts. for the error in installign MR which comes with dynmaics ax 2012 r3.
Solution:
I downloaded MR 2012 CU12, when i try configuring … got two errors :
Database configuration: The selected database doesn’t appear to be a Management Reporter database. Select a different database.
An unexpected error occurred while attempting to connect to the ERP database. Check the configured database server and name. Details about the error can be found in your deployment log.
Under: Dynamics (with data mart) connection info details…
Under DB name - I gave instance name
based on forume…I check the query SELECT DB_NAME() AS DataBaseName…it returns as “master”.
Do I need to seelct “master” or I should change to “DynamicsAX” where I want to install.
regards
