What ist the most current version of NAVISION Attain? I read a posting that mentioned version 3.1. Is this version already available in Germany? Regards Alarich
Hello, the actual Version of Attain is 3.01B with a Hotfix. 3.10 is not, at least from my NTR, released yet. We have a 3.10 since 4 weeks now and were told not to sell this version because of some more major changes that will be made until the official release. Normally Germany have the release of a new version some weeks later than the international or other english based localised versions, because the have the translation work to to. Regards Walter
SG 3.10A is out officially, so W1 3.10A must be out, one would reckon.
I have not received SG3.10A yet. I have only 3.10. Anyway, nice to hear to have the official version 3.10A available.
quote:
Originally posted by wish_man: SG 3.10A is out officially, so W1 3.10A must be out, one would reckon.
Wish Man: Please be so kind as to brighten the darkness of my ignorance: what means “SG” and “W1” in the NAVISION versions´ nomenclature? Regards Alarich
May I answer the question? SG means “Singapore Version”; that is a version localised for Singapore. W1 means “World-wide Version”; that is the base version of Navsion. Based on this version all NTR’s (like Navision Germany or Navision S’pore) build their local versions. For Germany you will have a DE3.10 then (you can check that out in the object designer, Version List). Regards Walter
The lastest version I have is GB3.10A, these version come round quickly. Whats this Navision with a vertical scroll bar and I was told that is something Navision would never have. Now try this go into the chart of accounts, drill down on any account an the press show all. Did you see the scroll bar change, neither did I, now try going up and down the records, ops!!! And does’t the toolbar look different when using Win XP but not 2000. Paul Baxter
The german version of 3.10 is announced for April. The current version in germany is is 3.01B
Hi Paul, According to Navision the toolbar and application icons have been redesigned for XP. They are only used within XP if other theme then the classic is chosen. Regards Kalman
