Missing the ntimer dll
Hi everyone,
I am running through an automation error whenever I am trying to run a certain form. After debugging, I discovered that the missing dll is NTimer.dll
What shall I do? If I copy the dll from another computer, would that be enough?
Thanks in advance :)
Will be necessary to copy and register it, but you can also use the OnTimer trigger of the forms.
Where to copy the file?
Infact, the dll didn’t exist before.The NAV isn’t installed in my machine, the IT guy just copied the folder Classic containing the shortcut ofinsql.exe into my computer and that’s what I am using to access NAV.
Place it in NAV directory (there should be a “Timer” subdirectory, if not create it): that’s where the installer put it.
