so we are currently implementing the RTC version, which is only compatible with Window Authentication. This is all great except for one problem: at the time of Classic, we used the SQL authentication.
We have over 4 years worth of data, and want to avoid having 2 usernames/userID for each employee. Is there a way to merge an SQL and a WIndows userID togehter? or maybe make one take over all the history and customers of the other?
Thank you in advance for any comments and/or suggestions.
I realize that the users will be AD users. My point was after the creation of the windows UserID is done, then can we make the windows UserID take over the old activities of their respective SQL UserID?
This would make it easier for management, reporting, ownership of accounts, sales history… basically once we move to WIndows UserID, the ownership on the old activities has to be moved as well, otherwise it will be pointing to a disconnected user…
I was asking about if UserID WIN can take over all the history of the UserID SQL
Let’S say I have an employee called John Smith. His SQL UserID is JS, his Windows UserID is Smith
WHen I print out a report for John’s department, I will get many activities with JS as the UserID and others as Smith.
Is there a way to tell Navision (SQL command maybe or a tool) that everything that had JS as UserID should now be replaced with Smith UserID?
I am not talking about user and role creation, they are created already, I am talking about the activity history and ownership of clients and sales orders and invoices…
