Microsoft Dynamics NAV flow fields
Good day all
I wrote some sql script to monitor overdue customer and their amounts outstanding. However I am unable to detect the correct Amount / Amount LCY value. I am querying the
[Detailed Cust_ Ledg_ Entry] table as the main source and also [Cust_ Ledger Entry] table. how can I work around this issue to get the correct value as on NAV. below is a screenshot of the values and flow field in NAV as well as my SQL script (which do not display the correct value)
SELECT
b.[Posting Date], --generally the posting date will be the same as the document date or after the document date
a.[Document Date],
a.[Due Date],
a.[Closed at Date],
b.[Entry Type],
CAST(c.[Blocked] AS NVARCHAR(5)) AS [Blocked],
CAST(b.[Document Type] AS NVARCHAR(10)) AS [Document Type],
CAST(b.[Customer No_] AS NVARCHAR(20)) AS [Customer No_],
–CAST(a.[Sell-to Customer No_] AS NVARCHAR(20)) AS [Sell-to Customer No_],
CAST(c.[Name] AS NVARCHAR(60)) [Customer Name],
CAST(b.[Document No_] AS NVARCHAR(10)) AS [Document No_],
CAST(a.[Description] AS NVARCHAR(50)) AS [Description],
CAST(b.[Source Code] AS NVARCHAR(10)) AS [Source Code],
CAST(b.[Currency Code] AS NVARCHAR(10))[Currency Code],
CAST(c.[Salesperson Code] AS NVARCHAR(10)) AS [Salesperson Code],
CAST(c.[Country_Region Code]
Hello, here you have a simple example which shows the Balance and Overdue Amounts.
SELECT [CRONUS AG$Customer].No_, [CRONUS AG$Customer].Name, SUM([CRONUS AG$Detailed Cust_ Ledg_ Entry].[Amount (LCY)]) AS [Amount(LCY)], sum(case when [CRONUS AG$Cust_ Ledger Entry].[Due Date]<getdate() then [CRONUS AG$Detailed Cust_ Ledg_ Entry].[Amount (LCY)] else 0 end) as [OverDueAmount(LCY)]
FROM     [CRONUS AG$Cust_ Ledger Entry] INNER JOIN
                  [CRONUS AG$Detailed Cust_ Ledg_ Entry] ON [CRONUS AG$Cust_ Ledger Entry].[Entry No_] = [CRONUS AG$Detailed Cust_ Ledg_ Entry].[Cust_ Ledger Entry No_] INNER JOIN
                  [CRONUS AG$Customer] ON [CRONUS AG$Cust_ Ledger Entry].[Customer No_] = [CRONUS AG$Customer].No_
GROUP BY [CRONUS AG$Customer].No_, [CRONUS AG$Customer].Name
HAVING ([CRONUS AG$Customer].No_ = '20000')
Hope it helps you. . .
