Hi All ,
Does Microsoft Dynamics AX 2012 or AX 2012 R2 is available in India for customers ?
much appreciate your feedback.
Many thanks
Hi All ,
Many thanks
AX 2012 is released in India with R 2 release. Check out the partner source for detail.
Pranav…
if you have partner source id then down load ax 2012 r2 from the above link…
Good to hear that AX 2012 R2 is available in india.
It means AX 2012 is not realized in india , directly AX 2012 R2 released in india .
Am i correct ?
But Indian localization database is not available… This will take some time…
With R2, AX 2012 is released only. AX 2012 is no different from R2. Since localization is involved, there is no point in releasing standard AX 2012 in India, though some global clients has already implemented standard AX 2012 in India as well.
Pranav…
Thanks Pranav,
AX 2012 R2 which is released in India , Does it has the Indian localization also ? or standard product only ?
Hi Reema,
Yes… R2 has indian localization feature. I think you need to install separate patch, earlier it was GLS layer but not sure in AX 2012. Anyway, that will be there in installation package.
Pranav…
Thanks Pranav kumar. [:D]
Indian Localization for Dynamics AX 2012 is known as Ax 2012 R2 and is available for the partner source .
