Which method we should use then to pick up a file from windows file picker dialog?
I don’t know your specific requirements, but File::GetFileFromUser() may be what you’re looking for.
Here is my code:
public static void main(Args _args)
Dialog dialog = new Dialog();
DialogField dialogField;
AsciiIo importFile;
str filePath,fileNameOnly;
filetype type;
container record;
str delimiter = “,”;
int totalRecords;
CustGroup custGrp;
dialogField=dialog.addField(extendedTypeStr(FilenameOpen),“Select File”,“Select file to import”);
dialog.caption(“File Picker”);
dialog.filenameLookupFilter([‘csv’,’*.csv’]);
if(!dialog.run())
return;
[filePath, fileNameOnly, type] = fileNameSplit(dialogField.value());
importFile = new AsciiIo(dialogField.value(), ‘R’);
if((!importFile) || (importFile.status() != IO_Status::Ok))
warning(“Error in opening import file”);
throw(Exception::Error);
importFile.inFieldDelimiter(Delimiter);
try
ttsbegin;
custGrp.clear();
record = importFile.read(); // First row - Column name - Header
while(importFile.status() == IO_Status::Ok)
if(!record)
break;
totalRecords = totalRecords + 1;
custGrp.clear();
custGrp.CustGroup = conPeek(record, 1);
custGrp.Name = conPeek(record,2);
custGrp.insert();
ttscommit;
catch(Exception::Error)
Throw(Exception::Error);
info(strFmt(“Total Read Records = %1”,totalRecords));
from above code “dialog.filenameLookupFilter([‘csv’,’*.csv’]);” throws error. above code works in AX 2012 but not working in D365OF
your suggestion is highly appreciated,
That’s correct. This piece of code is for older versions of AX; it’s not applicable to Dynamics 365.
