Method Sequence while opening a form
Recently I was learning about Method sequences when a form is opened in AX 2012. I found the following to be useful:
msdn.microsoft.com/…/aa608211(v=ax.50).aspx
But, I can’t understand what the “Thread number” mean. So, please explain the sequence of methods of both form & datasource. Thanks in advance!
Check this blog where it has been mentioned clearly.
http://kollidynamics.blogspot.in/2011/08/sequence-of-methods-in-form-level-in-ax.html
http://alfasith.blogspot.in/2013/07/method-sequences-in-dynamic-ax.html
