hi Experts,
I have Created a method In DPclass (I have to show Category ) but it gives following error
“Method never returns a value”
private str Category(ItemId _itemId)
ECORESCATEGORY eCORESCATEGORY ;
INVENTTABLE iNVENTTABLE ;
EcoResProductCategory ecoResProductCategory;
while select * from ECORESCATEGORY
exists join iNVENTTABLE
exists join ecoResProductCategory
where EcoResCategory.RecId == EcoResProductCategory.Category
&& INVENTTABLE.PRODUCT == EcoResProductCategory.PRODUCT
&& iNVENTTABLE.ItemId == _itemId
//info(strFmt("%1's Category ",ECORESCATEGORY.NAME));
return strFmt (ECORESCATEGORY.NAME);
Please guide me
You don’t understand yourf own code because you made it difficult to read. Let me rewrite it for you:
private str category(ItemId _itemId)
EcoResCategory ecoResCategory;
InventTable inventTable;
while select ecoResCategory
exists join inventTable
where inventTable.ItemId == _itemId
where ecoResProductCategory == ecoResCategory.RecId
&& ecoResProductCategory.Product == inventTable.Product
return ecoResCategory.Name;
Now you can easily see that there is no return statement for the situation when the query doens’t fetch any record. You should either return a value or throw an exception.
By the way, there is no point using a while loop if you end the method when you find the first record. Therefore you could do this:
select firstOnly Name from ecoResCategory
&& ecoResProductCategory.Product == inventTable.Product;
