Dear All,
i am facing a problem while opening a page. it says the metadata of the table is invalid. see event viewer for more details. when i look into event viewer i saw this mesez ::
Service: MicrosoftDynamicsNavServer
User: W08-DB01\Chandra
Type: System.Xml.XmlException
LineNumber: 43
LinePosition: 182
Message: ‘’, hexadecimal value 0x14, is an invalid character. Line 43, position 182.
StackTrace:
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res, String[] args)
at System.Xml.XmlTextReaderImpl.ThrowInvalidChar(Int32 pos, Char invChar)
at System.Xml.XmlTextReaderImpl.ParseAttributeValueSlow(Int32 curPos, Char quoteChar, NodeData attr)
at System.Xml.XmlTextReaderImpl.ParseAttributes()
at System.Xml.XmlTextReaderImpl.ParseElement()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.LoadXml(String xml)
at Microsoft.Dynamics.Nav.Service.Metadata.MetadataProvider.GetNavObjectAsXMLDocument(Int32 id, ObjectType navObjectType)
at Microsoft.Dynamics.Nav.Service.Metadata.MetadataProvider.<>c__DisplayClass1.b__0()
Source: System.Xml
what may be the problem ?? i couldnt identify the problem…
