HI All,
Can i create a new sub menu and menu item in the project, how its reflect with AOT.
Can you please explain.
HI All,
Hi srinivas,
Can you tell me the whats your need? AOT -->Menu item having Three Parts 1.Display 2.Output 3.Action.
DIsplay method call the form design, OutPut method call the Report, Action methodcall the classes & queries.
Hi Srinivas,
You can create a MenuItem or Menu in project directly by right click on project or create it in AOT and drag it into your project both are acceptable.
The objects you are seeing in projects are just mirror images of objects in AOT.
Thanks for our replay i have achieve it.
Can you please mark the helpful reply (replies) as the verified solution? If the solution hasn’t been posted here, can you add it, so others with the same problem can find it here?
