The best material is the manual published on partnersource and using in conjunction with the labs this will give you everything you need to pass if you understand the software and what you have done.
i’m working in the published manual , by there are a lot of things is not clear for me , also i try to get a real life experience in that filed of implementation
i read the manful and look at the software after that make the LAB
