Maximum Size For An Axapta Database
I’ve been told that Axapta can run with MS SQL or Oracle as a Database back end. But what’s the maximum database size you can get with Axapta native DB engine ? with an tarek_demiati@ureach.com
The only limit for both is determined by each database package, which is hundreds of Terabytes. However, more practical, it’s limited by the amount of disk space that you have available.
And the size of int (32 bit) Erling Damsgaard Thy Data Center A/S
