We would like to maximise the number of times a user-id can start a Navision Attain-client. So far we have not been able to find a property or parameter to do so. Maybe you can help us in our Quest? Hans Fousert Schouw Informatisering The Netherlands
Do you mean limit how many sessions exist for each USERID? The only thing I can think of is to have the system check the Session table when a User Logs in, and return an error if more than X amount of sessions exist for that user ID.
Hi Hans, You wrote maximise but you meant limit the No. of sessions one can open. There’s solution in download section for SQL Server option. But for Navision Server, none so far. We can check and warn the user(s) and also prevent them from working in extra sessions but no solution to quit them automatically and decently(w/out using questionable techniques like generating run-time error etc.) to forcibly quit the user. Regards
