Dear all ,
What is the max throughput in inventory closing / recalculation use for ?
The default in Ax always set in 100.
I check all the answer in this forum, it is related with bom level.
Let say if i have bom level until 5 level, if i set max throughput 4, so bom level 5 will not be checked.
I’ve checked the maximum bom level is 3 in my environment.
What happen if i set my max throughput in 20. It is less then default in AX 100.
The inventory transaction on month February is about 200.000 records transaction.
Is it impact to performance when running inventory closing February ?
Fastest or slow ?
Kindly advise
