When we run Master Scheduling batch job from below path (Master Planning > Periodic > Master Scheduling), its creating planned orders - some with start date and end date and some with out Start Date(ReqPO.SchedFromDate) and End Date.
The batch job status changes to ENDED but we can see a log that shows below error
One cause is mentioned here:
The issue in this was caused by the AOS Server configuration option “Enable the hot-swapping of assemblies for each development session” being enabled on the server. This option should NOT be activated on production environments. blogs.msdn.microsoft.com/…/
Can you guide me on what should i do with this comment that is on that post you have sent. I didnt quite get that.
“The resource scheduling engine uses a hard-coded resource name for jobs that do not include a resource or calendar. The hard-coded resource name is “EmptyRes”. This hard-coded name might conflict with actual resource names. There is no workaround for this issue.” The solution for this is to create a new resource: “emptyres”.
Yes we checked the release note details too. But nothing helped.
I would just start unpicking it. So where you have orders with no dates look at the resources, remove the associated calendars.
What the above means is you should not create a resource called “EmptyRes” as an actual resource with a calendar, but I dont know anyone that would do that, it makes no sense.
