I have several fob files to import as part of an integration to NAV 2009.
To make the deployment as seamless as possible, rather than manually going to File > Import in the Classic Client x number of times, would like to import them en mass i.e all at the same time in a one off process. Is this possible?
They are all unique fobs so won’t already be in the system to be deployed into.
You know I was considering giving Pete the same tip, but refrained as IMPORTOBJECTS only allows to import using .txt or .xml format. Unfortunately not .fob.
