i just started using maps and i have a question. I want to build a map to use it for the args-object (e.g. args.parmObject(MyMap)…).
But it seems that boolean-values do not work here (and the map should contain a string, an int and a boolean…).
Any help would be great!
This is a small piece of test-code - i retrieve an exception in the line “bTest = mapItems.lookup(‘boolTest’);”:
static void FP_Test04(Args _args)
Map mapItems;
boolean bTest;
mapItems = new Map(Types::String, Types::AnyType);
mapItems.insert('boolTest', true);
bTest = mapItems.lookup('boolTest'); //EXCEPTION
if (bTest) {
// Do something...
Thanks in advance,
Frank
