Environment: Navision 5.01 W1; native Database
Goal:
1.) Create a Production Order from the Order Planning window based on Sales Order Demand. - Works ok. [:)]
2.) Reserve the Item on the sales order against the Production order - Works ok. [:)]
3.) Have all the components of the production order reserved against stock automatically. STOP [6] This only works if the location does not use BINS. As soon as bins are used, there is no automatic reservation, even though one can mnaully reserve each component.
Is this a setup-problem or a bug or a “feature”? Thanks for any insight you might have.
