Manufacturing - BOM. Certified Status Error.
Hello everybody and greetings from Mexico.
I’m making up a new BOM, but when I try to change the status from “Under development” to “Certified”, I get the error: Notification Error Primary Key ‘’ does not exist. Any suggestion? Do I missing some other kind of setup?
Thanks in advance.
Best Regards.
Nope no setup issue, I would suggest someone has been modifying the BOM table and has not created it with a primary key. Contact your partner or internal development team/person.
Thank you Adam, I just add a record with an space Id in the table Notification Setup (8000).
Running form 8000 inserts a blank record, which would have also solved you issue rather than inserting directly in the table.
