"Mandatory" and "Primary stocking" check box in storage dimension group definition in AX2012
Dear all:
Can any one explain to me the purpose of using the “Mandatory” and “Primary stocking” check box in storage dimension group definition in AX2012 with explain please??
Many thanks in advance
Mandatory - When you select “Mandatory dimension” it will appears on all journals and transactions, and you must specify a dimension value when you do any kind of transactions or entries. You have to (must & should i can say) enter it if not it will not allow you to move forward for further processing.
Primary Stocking - When you select the “Primary Stocking” it tells dimension must be specified when the items purchased or sold it should physically updated.
Mandatory: If this checkbox is selected then you can set the warehouse dimension to be mandatory for a storage dimension group. When the warehouse dimension is mandatory in a storage dimension group, the dimension must be specified when you do a PO or a SO.
Primary Stocking: If the this parameter is selected, then it is mandatory that the dimension be entered before any physical updates.
Thanks & Regards,
Parashar Banerjee
Thank you very very much.[:)]
Regards
