Dear Experts,
We want to mandate Cost Center (Financial Dimension) @ PO > Invoice Level. We cannot go to individual account which are affected @ the time of PO Invoice as those account are coming in other trans. also. So how to achieve the same??
Thanks very much in advance.
AX 2012 Account Structure is designed to set the requirements of financial dimension, using ledger account as its basis. In your case, i understand this is not applicable.
Have you tried customizing the Form in AOT? Set the Properties > Mandatory of the particular field to ‘Yes’. I think that should do it.
Hey Tina,
We are using AX 2009 and not AX 2012
