Management Reporter with AX 2012
I would like to know about how we can use management reporter along with AX 2012?
Yash Thakkar
MR works as an extension for financial statement in AX. In MR after you make the connection setup for AOS and company, you can create row defination and collumn defination as required for the financial statement. In MR you also have tree defination which is used for financial dimensions.
MS has released latest version of MR for 2012 which is more optimized with respect to report run.
You can find MR related documents on partner source.
Pranav…
