On the Menu Forms, Navision has changed the controls in version 3.60. The CommandButtons used to be listed in the CurrForm.[Control] list, and I could set the VISIBLE property based upon the user. Now, the CommandButtons are not available as controls. How can I make the CommandButtons appear as a controls for the current form so I can dynamically set their properties? Am I just missing something obvious here? Thanks
Hi, Firstly u give the names to all command buttons. After that the command buttons will be listed in currform.[control]. Then u can perform the desired task. Cheers
