Does anyone know how to view the COA account balance in AX 2012? I use the same steps in AX 2009, set up → Balance, and select the financial year. But the balance is always 0.
Anyone has idea?
Anyone has idea?
The balance appears on the right side of the screen. If you have posted transactions and balance is not updating then i will suggest you to rebuild and update balances on financial dimension set. That can be found in GL Setup under financial dimensions.
Pranav…
