Macro example
Hai all,
I am working on Macros. I am geting syntax error in the below code in the line #LMacReportLog. Could you please help me.
static void MacroExample(Args _arg)
int a =1;
#localmacro.LMacReportLog
a
print(“Hai-%1 --LM, print.”);
info(“Hai-%1 --LM, Infolog.”);
#endmacro
#LMacReportLog
pause;
Try this out:
int a =1;
#endmacro
#LMacReportLog
pause;
Hai vishal,
Thanks for the reply. My problem is, I want to catch integer value in Macro. That is i want to include “a” in the macro.
Can u include ‘a’ in the lacal macro and rectify the problem.
Reference to a macro is simply replaced by its body and a is not a valid X++ statement. You could use the variable in a valid statement (e.g. info(int2str(a));) but it’s strange to have macros that depend on specific variable names. The right way is to use parameters - for example:
int a = 1;
    info(int2str(%1));
#endmacro
#LMacReportLog(a)
This would help you:
int a =1;
a
#endmacro
info(strfmt("%1", #LMacReportLog));
Hai Vishal and Martin,
Thanks for ur help.
