Hi, I have a problem with the UOM conversion in stock demand worksheet.
I try to create a Stock Request with 1000 ML, and when i assigned it appeared 1000 L in Stock Demand Worksheet. The expected result should be 1L (L is base UOM). Pls help me to fix it.
Thank you all.
It sounds like your Unit of Measure (UOM) conversion factor is set up incorrectly on the Item Card, causing the system to treat ML and L as equal units.
Here’s the quick fix for this issue in Business Central/NAV:
The Fix: Item Unit of Measure
The problem is that when you enter 1000 ML, the system is reading the conversion factor as 1 ML = 1 L.
Go to the Item Card for the item in question.
Navigate to Related → Item → Units of Measure.
Find the line for the ML Unit of Measure.
The Qty. per Unit of Measure field on the ML line should be 1000.
Setting the field to 1000 tells the system that 1 Base Unit (L) = 1000 ML. Once corrected, entering 1000 ML will correctly convert to 1 L on your Stock Demand Worksheet.
