I have a complex set of data that I retrieve via a HTTP request and need to output the JSON response into a fields in a table…
The structure of the data is;
“total”: null,
“items”: [
“key”: “key1”,
“label”: “key1 label”,
“value”: “value of field”
“key”: “key2”,
“label”: “key2 label”,
“key”: “key3”,
“label”: “key3 label”,
“value”: {
“value”: “another value”,
“ongoing”: 9999
"total": null,
"items": [
"key": "key1",
"label": "key1 label",
"value": "value of field"
"key": "key2",
"label": "key2 label",
"key": "key3",
"label": "key3 label",
"value": {
"value": "another value",
"ongoing": 9999
there could be 1 object or 500+
I need to be able to loop through each array element signified by “total”:null as the start of each element and then output to a table…
Struggling to be able to loop through the JSON I’ve received back via HTTP request…
Any help would be greatly appreciated!!!
Cheers
Steve
Hi @Steve_Simpson,
First, I think there are some errors in this Json file. I think this is the correct version:
"total": null,
"items": [
"key": "key1",
"key": "key2",
"key": "key3",
"value": {
"ongoing": 9999
"total": null,
"items": [
"key": "key1",
"key": "key2",
"key": "key3",
"value": {
"ongoing": 9999
You need two foreach to process the data:
// read the main Json array
JsonArr.ReadFrom(VarText);
// procees each element of the array:
foreach JsonTkn in JsonArr do begin
// at this point, in the first iteration, JsonTkn has the first Json Object
JsonObj := JsonTkn.AsObject();
JsonObj.Get('total', JsonTkn);
// do something if total is null
if JsonTkn.AsValue.IsNull() then begin
// load the second array
JsonObj.Get('items', JsonTkn);
JsonArr2 := JsonTkn.AsArray();
// process the second array
foreach JsonTkn in JsonArr2 do begin
// at this point, in the first iteration, JsonTkn has the first Json Object from 'items'
JsonObj2 := JsonTkn.AsObject();
JsonObj2.Get('key', JsonTkn);
// do something with 'key' value
JsonObj2.Get('label', JsonTkn);
// do something with 'label' value
JsonObj2.Get('value', JsonTkn);
if JsonTkn.IsValue() then
// do something when "value" is a value
else
// do something when "value" is an object
end;
end;
end;
I hope you will find this usefull.
