Hi All, (again)
I would like to ask for help for my rdlc report.
i’ll cut to the chase.
I have a Customer, and in my report.
the open Entries. customer’s Ledger Entries. should be present in my report(already did this)
and then I’m want to show all of the lines in the Detailed Cust. Ledger Entries of that line in Cust. Ledger Entries. Regardless The Document type.
however, my report only displays the last amount in the first line in my report
Hope you could Help Me Thanks!
Hii,
I think you did not use looping the line in repeat until, What coding you did for this ?
Hi i did use Looping
Repeat Until. but in my layout it only shows 1 line from the detailed cust. ledger entries
here’s my code
DetLedgEntry.RESET;
DetLedgEntry.SETRANGE(DetLedgEntry.“Cust. Ledger Entry No.”,DtldCustLedgEntries.“Cust. Ledger Entry No.”);
DetLedgEntry.SETRANGE(DetLedgEntry.“Entry Type”,DetLedgEntry.“Entry Type”::Application);
IF DetLedgEntry.FINDFIRST THEN BEGIN REPEAT
DocNoCustLedgEntr := DetLedgEntry.“Document No.”;
PaidAmount := ROUND(DetLedgEntry.Amount,0.001);
MESSAGE(FORMAT(PaidAmount));
UNTIL DetLedgEntry.NEXT = 0;
END
Please change your code, in place of FINDFIRST you have to use FINDSET and Remove BEGIN and END.
DetLedgEntry.RESET;
IF DetLedgEntry.FINDSET THEN
REPEAT
