Dear Friends,
I hv a problem in lookup Method. I hv External No that can lookup to table A and B . What should I write
ex:
Table A
No Name
MR-001 MRMR
MR-002 MRMRMR
and
Table B
No Name
MB-001 MB
MB-002 MBMB
so when i lookup i hv these data to choose
Lookup :
MR-001
MR-002
MB-001
MB-002
is it possible?
Create a union query in AOT and use it in your lookup method. See How to: Combine Data Sources in a Union Query for details about such queries.
Or change the approach - maybe users should first choose a type of record and then get a lookup from the right table (that can be modeled by relations).
kranthi
November 12, 2013, 12:14pm
3
You can build a lookup form with multiple datasources…
how shoul i write the code?
i am writting the code below, but it return error
sysTableLookup=SysTableLookup::newParameters(tableNum(InventJournalTable), this);
sysTableLookup=SysTableLookup::newParameters(tableNum(FKT_Repacking), this);
query = new Query();
query.queryType(QueryType::Union);
queryDataSourceCode = query.addDataSource(tableNum(InventJournalTable));
queryDataSourceCode.unionType(UnionType::UnionAll); // Include duplicate records
queryDataSourceCode.fields().dynamic(false);
queryDataSourceCode.fields().clearFieldList();
queryDataSourceCode.fields().addField(fieldNum(InventJournalTable, JournalId));
queryDataSourceCode.addRange(fieldNum(InventJournalTable, JournalNameId)).value(“IMRC”);
queryDataSourceCode2 = query.addDataSource(tableNum(FKT_Repacking));
queryDataSourceCode2.unionType(UnionType::UnionAll); // Include duplicate records
queryDataSourceCode2.fields().dynamic(false);
queryDataSourceCode2.fields().clearFieldList();
queryDataSourceCode2.fields().addField(fieldNum(FKT_Repacking, No));
queryDataSourceCode2.addRange(fieldNum(FKT_Repacking, No)).value(“MR*”);
kranthi
November 15, 2013, 2:42pm
6
SysTableLookup will not support lookup fields from multiple tables.
