hi,
in my form i have to add new field .in that field when i say click on drop down then i should getthe look up of employee name and employee id .
any suggestions???
hi,
any suggestions???
Which version you are using?
In AX 2009 you can use the emplId EDT, but in AX 2012 there were significant changes made to the employee entity.
take a look at the HCMWorkerLookup class, lookupWorker method. See the cross references for that method to understand the usage.
hi…
m working ax 2012 R2 , …customising on “InventQualityOrdertable” form where i am trying to get employee namefrom DirPartyTable & employee id from “HCM Worker” table .
is there another way to do this , mine s not workimg.
have you tried HCMWorkerLookup class?
i just checked lookupWorker method of HCMWorkerLookup class , i can see following code. but not sure about editing part [:(]
else if (stringControl)
formRun = FormAutoLookupFactory::buildLookupFromCustomForm(stringControl, workerLookupForm, AbsoluteFieldBinding::construct(fieldStr(HcmWorker, PersonnelNumber), tableStr(HcmWorker)), args);
stringControl.performFormLookup(formRun);
public void lookup(FormControl _formControl, str _filterStr)
Query query = new Query();
QueryBuildDataSource qbds;
QueryBuildDataSource QbdsJoin;
SysTableLookup sysTableLookup = sysTableLookup::newParameters(tableNum(HcmWorker), _formControl);
qbds= query.addDataSource(tableNum(HcmWorker));
QbdsJoin= qbds.addDataSource(tableNum(DirPartyTable));
QbdsJoin.addLink(fieldNum(HcmWorker,PersonnelNumber),fieldNum(DirPartyTable,Name));
//QbdsJoin.addRelation(fieldNum(HcmWorker,PersonnelNumber),fieldNum(DirPartyTable,Name))
QbdsJoin.relations(true);
QbdsJoin.joinMode(JoinMode::InnerJoin);
//QbdsJoin.addRelation(fieldNum(HcmWorker,PersonnelNumber),fieldNum(DirPerson,Name));
sysTableLookup.parmQuery(query);
sysTableLookup.addLookupfield(fieldNum(HcmWorker, PersonnelNumber),true);
//sysTableLookup.addLookupMethod(tableStr(HcmWorker.Name()));
sysTableLookup.addLookupfield(fieldNum(DirPartyTable,Name));
sysTableLookup.performFormLookup();
finally i got the look up in my form …with the help of relation with HcmWorker.
but in lookup when i select any record , am getting a warning as “Field ‘Project ID’ must be filled in”.
where is the projectId?
finally i am done with this task , its working well.
thanks
