Hi Friends,
I have small Doubt .Please look into the Following
I have one table(Table1) having two fields like Field1 and Field2.
My Requirement is .
i want to show the Look up of two fields of data into single Lookup Fields
Ex: Field1 having the data like 1,2,3
Fields2 haing the data like 4,5,6.
so then i want show the data of two fieds into single lookup fields data
lokkup contains 1,2,3,4,5,6 in single lookup fields
thansk in advance
Murali.
Use a union query, if you version of AX supports that.
Please always attach a tag with your version of AX; it’s in your own interest.
Hi martin,
I am using the Ax 2009.
Thanks for reply…But union is used two different data sources .
here i have only one data source and two fields so how i will use the Union for this…
It uses two data sources, but nothing prevents you from using the same table in two data sources. Using pseudocode, your requirement looks like this:
select Field1 from Table1
union
select Field2 from Table1
Hi martin,
Thnaks for reply…that is ok but i want to show lookup by using the Queries .
can u help me that?
Thanks in advance,
Murali
Sorry, I don’t understand what you mean by “to show lookup by using the Queries”. Could you explain your problem in better details?
Hi martin,
Actually i have Form and Adding the new Field.
I want to show the Lookup in that field which it requires data of other table of two fields data…
Ex: table contains Two fields like field1 and field2.field1 having the data 1,2,3 and field2 haing the data 4,5,6 then
Fielld 1 / Fielld2
1 4
2 5
3 6
In the Lookup i want to show one column and these total data like 1,2,3,4,5,6
Thanks in advance,
Murali
Yes, I thought that’s already answered. What’s the problem?
By the way, I suspect that the requirement is actually a sign of wrong database design (but I don’t know your particular situation, of course).
