hi friends,
I was wrote a look method in form Data Source Level.here am mentioned the code below
public void lookup(FormControl _formControl, str _filterStr)
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tablenum(PurchTable), _formControl);
Query query = new Query();
QueryBuildDataSource queryBuildDataSource = query.addDataSource(tablenum(PurchTable));
QueryBuildRange queryBuildRange = queryBuildDataSource.addRange(fieldnum(PurchTable, OrderAccount));
PurchTable PurchTable;
if (ProductInform.VendorAccountNumber == “”)
sysTableLookup.addLookupfield(fieldnum(PurchTable, PurchId));
sysTableLookup.addLookupfield(fieldnum(PurchTable, PurchName));
sysTableLookup.addLookupfield(fieldnum(PurchTable, OrderAccount));
queryBuildDataSource.addRange(fieldnum(PurchTable,PurchStatus)).value(queryValue(PurchStatus::Backorder));
sysTableLookup.addLookupfield(fieldnum(PurchTable, PurchStatus));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
else
queryBuildRange.value(queryvalue(ProductInform.VendorAccountNumber));
it works fine…
It shows like that
PurchId PurchName Status
23456 Lcd TV Open Order
258963 Black Open Order
my problem is while am select Filter by Field in Status Field.And am entered Invoiced means its alaso displayed.
but my requirement is only display the open order not others Like Invoiced,Receive…
Pls any one help form that in Ax 2009…
