Log
Good Morning , I wonder how to retrieve the proper log .
I need to retrieve the log information regarding a worksheet to know edit or change ( and when) a worksheet .
Hi
As long as you have activated this on the change log, you can view changes re change log entries. Just search for Change Log Entries if Nav 2009 RTC on after. Or Admin, Application Set up, General.
Neil
yes, you need to activate the standard change log setup and set the fields for which you would like to track the changes.
