load barcode data
hi all
i load the data for iteminventbarcode table
i loaded sucessfully
but when i check in item - > setup → barcodes , i cant see the datas in form fields
but the data available in table…
wht is the issue :frowning:
pls anyone help me
thanx iin advance
pls anyone help me
urgent
This is because it’s inner joined to InventDim and that’s why it’s not displaying your records.
You probably left the InventItemBarcode.inventDimId field blank. You need to initialize it with a dimension. You might be able to get away with putting “AllBlank” in that field and it will probably show up.
thanx alex :slight_smile:
