Hello.
In Dynamics AX 2009.
How can I create my own query by code, and link it to an existing grid of a form?
Need sample please.
(i.e salesLine that linked to sales table etc…)
Hello.
Need sample please.
hi,
just try this example
Example: Building a query in X++
The following code demonstrates how a query is built from scratch in X++. This
query returns all sales orders, from the SalesTable, for customer ‘4008’, sorted
by the SalesId.
Query query;
QueryRun queryRun;
QueryBuildDataSource qbds;
QueryBuildRange qbr;
SalesTable SalesTable;
query = new Query();
//this line attaches a table to the qbds data source object
qbds = query.addDataSource(TableNum (SalesTable));
//this line attaches a range to the ‘SalesTable’ //data
source, the range is the CustAccount
qbr = qbds.addRange(FieldNum (SalesTable,CustAccount));
// The range is set to ‘2001’
qbr.value (‘2001’);
// The query will sort by sales id
qbds.addSortField (FieldNum(SalesTable,SalesId));
// The queryRun object is instantiated using the query
queryRun = new QueryRun(query);
// The queryRun object loops through all records returned
while (queryRun.next())
// The current record is assigned to the salesTable
variable
SalesTable = queryRun.get(tableNum(SalesTable));
print SalesTable.SalesId;
writing the query for two tables is as below. But If u can explain me ur second requirement, it will help me to specify solution.
Query query;
QueryRun queryRun;
QueryBuildDataSource qbdsSalesTable, qbdsSalesLine;
QueryBuildRange qbrSalesTable, qbrSalesLine;
SalesLine salesLine;
qbdsSalesTable = query.addDataSource(TableNum (SalesTable));
qbrSalesTable = qbdsSalesTable.addRange(FieldNum (SalesTable,SalesId));
qbrSalesTable.value(‘SO001’);
qbdsSalesLine = qbdsSalesTable.addDataSource(TableNum (SalesLine));
qbdsSalesLine.relations(True);
qbrSalesLine = qbdsSalesLine.addRange(FieldNum (SalesLine,SalesId));
qbrSalesLine.value(‘SO001’);
while(queryRun.next())
SalesTable = queryRun.get(TableNum(SalesTable));
salesLine = queryRun.get(TableNum(salesLine));
if(queryRun.changed(TableNum(SalesTable)))
print salesTable.SalesId;
if(queryRun.changed(TableNum(SalesLine)))
print SalesLine.SalesId;
Hope it will help you…[:D]
That’s OK - but almost.
I need to connect the query to a grid on form (The grid is connected to FromDataSource, but how can I do that manually).
