Need help: trying to display LCY in the header of a report
Under C/AL globals I deifned GenLedSetup as record from table General Ledger Setup
In the report sections I put text box with source GenLedSetup.“LCY Code”. However, when I run the report, LCY is blank. What am I doing wrong?
Help anyone
DaveT
2
Hi Iggy,
Welcome to the Dynamics User Group!
You need to get the record first … use GenLedSetup.GET;
what is your data item if “General Ledger Setup” is not your data item then you need to get the record from General Ledger Setup and the display;
place the below code at OnPreSection() of your report header
General Ledger Setup.reset; --YThis code will reset the table
General Ledger Setup.get(’’); – This will get record based on Primary Key
now place a text box and change its source expression to General Ledger Setup.“LCY Code”
Jerome Marshal.J
