Is there any possibility provided by the navision database itself, to find out when a table was used the last time (in Navision 2.0) (i definitely do not want to program any modify/insert/delete triggers [:D])
In V3.60 you can track data changes (but not simple “view only” accesses), through use of the Change Log feature. In V2.50 you cannot do even this without the addition of a modification.
quote:
Thank you! So it seems, one more reason for a kernel upgrade!
