Hi guys,
I need to write a script, that will install KB3000700 kernel HotFix for AX 2009 clients, whitch looks like this:
@ECHO off
@SET SETUP_PATH=\\axaptauat\AX\Install\KB3000700\axupdate.exe
"%SETUP_PATH%"^
AcceptLicenseTerms=1^
HideUI=1^
InstallComponents=1
My problem is that I also need an uninstallation script, that will silently rollback this update in case of any problems, but I can’t find axupdate syntax elements for components removal. I found out that I can be removed manually in “Programs and functions” tab when displaying updates, but via commandline, with “wmic” command it shows only Windows Updates positions and programs installations ( no updates informaton).
Via Powershell there is the same result. I’ve tried:
Get-WmiKey win32_product or qfe
Have anybody ever had this problem before? Is the only solution is to uninstall client completely and install it again?
