I am working on parsing a Json response in NAV2015.
Thanks to Gunar’s blog post http://www.dynamics.is/?p=2303#comment-1747 , and suggested modifications in the comments, I was able to parse one single Json object that had nested arrays.
Example: There are several accomplished events…
"waybill": {
"status": null,
"number": "123456",
"date": "2018-05-07",
"flipAuth": false,
"storageCharges": {
"chargesApplicable": "N/A"
"accomplishedEvents": [{
"name": "Interchange Received ",
"dateTime": "2018-05-07T17:00",
"trainIdCarrierOrReason": "UP received from CCT",
"location": {
"city": "Ptstockto",
"state": "CA"
"name": "Yard Departure",
"dateTime": "2018-05-08T22:03",
"trainIdCarrierOrReason": "YSTST 08",
"location": {
"state": "CA"
But now what happens if I were to get several waybills back in my response?
Using the Posting Exch. Field Table 1221 to store the data after parsing, I think that I might be able to use the line number to differentiate between the different waybills, but haven’t found a way to implement it.
Does anyone have any suggestions?
Here is the code I use to parse the Json response.
PROCEDURE ReadJSon@5(VAR String@1000 : DotNet "'mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.String";VAR TempPostingExchField@1002 : Record 1221);
VAR
JsonToken@1001 : DotNet "'Newtonsoft.Json, Version=4.5.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed'.Newtonsoft.Json.JsonToken";
PrefixArray@1006 : DotNet "'mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Array";
PrefixString@1005 : DotNet "'mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.String";
PropertyName@1008 : Text;
ColumnNo@1003 : Integer;
InArray@1007 : ARRAY [250] OF Boolean;
ArrayDepth@1102610000 : Integer;
BEGIN
PrefixArray := PrefixArray.CreateInstance(GETDOTNETTYPE(String),250);
StringReader := StringReader.StringReader(String);
JsonTextReader := JsonTextReader.JsonTextReader(StringReader);
WHILE JsonTextReader.Read DO
CASE TRUE OF
JsonTextReader.TokenType.CompareTo(JsonToken.StartObject) = 0 :
JsonTextReader.TokenType.CompareTo(JsonToken.StartArray) = 0 :
BEGIN
InArray[JsonTextReader.Depth + 1] := TRUE;
ColumnNo := 0;
ArrayDepth += 1;
END;
JsonTextReader.TokenType.CompareTo(JsonToken.StartConstructor) = 0 :
JsonTextReader.TokenType.CompareTo(JsonToken.PropertyName) = 0 :
BEGIN
PrefixArray.SetValue(JsonTextReader.Value,JsonTextReader.Depth - ArrayDepth);
IF JsonTextReader.Depth > 1 THEN BEGIN
PrefixString := PrefixString.Join('.',PrefixArray,0,JsonTextReader.Depth - ArrayDepth);
IF PrefixString.Length > 0 THEN
PropertyName := PrefixString.ToString + '.' + FORMAT(JsonTextReader.Value,0,9)
ELSE
PropertyName := FORMAT(JsonTextReader.Value,0,9);
END ELSE
END;
JsonTextReader.TokenType.CompareTo(JsonToken.String) = 0 ,
JsonTextReader.TokenType.CompareTo(JsonToken.Integer) = 0 ,
JsonTextReader.TokenType.CompareTo(JsonToken.Float) = 0 ,
JsonTextReader.TokenType.CompareTo(JsonToken.Boolean) = 0 ,
JsonTextReader.TokenType.CompareTo(JsonToken.Date) = 0 ,
JsonTextReader.TokenType.CompareTo(JsonToken.Bytes) = 0 :
BEGIN
NewValue := FORMAT(JsonTextReader.Value,0,9);
TempPostingExchField."Posting Exch. No." := JsonTextReader.Depth;
TempPostingExchField."Line No." := JsonTextReader.LineNumber;
TempPostingExchField."Column No." := ColumnNo;
TempPostingExchField."Node ID" := PropertyName;
TempPostingExchField.Value := FORMAT(JsonTextReader.Value,0,9);
TempPostingExchField."Posting Exch. Line Def Code" := JsonTextReader.TokenType.ToString;
IF NOT TempPostingExchField.INSERT THEN BEGIN
//TODO
END;
END;
JsonTextReader.TokenType.CompareTo(JsonToken.EndConstructor) = 0 :
LineNo += 1;
JsonTextReader.TokenType.CompareTo(JsonToken.EndArray) = 0 :
BEGIN //add
InArray[JsonTextReader.Depth + 1] := FALSE;
ArrayDepth -= 1;
END;
JsonTextReader.TokenType.CompareTo(JsonToken.EndObject) = 0 :
IF JsonTextReader.Depth > 0 THEN
IF InArray[JsonTextReader.Depth] THEN
ColumnNo += 1;
END;
END;
