Dear Experts,
I am using AX 2012 R2.
i have one production order with status Started and in reset status current status is Released now i am trying to reset from Released to Estimated or Created.
I am getting below Warning.
Sreenu
Dear Experts,
Sreenu
Have you specified the default journal names in production parameters?
Hi Kranthi,
Thanks for your quick reply.
In my setup already i have default journal names.
Sreenu
This seems to be a setup issue. In Infolog if you are able to see the edit button then click on ‘edit’ button from there you can trace the warning message and identify the issue cause.
Are the journals copied into the production order header in that version? I mean the parameters are populated but they may reference the order. I would also suggest debugging it, the message could be misleading you
Manjunadh you are right its setup issue we need add route card journal name also in Default Journal names, now it working fine.
