I imported in, using a dataport, a year’s worth of GL history, a lot of line, and this error message comes up.
Document No. 2370 is out of balance by -7,148.09. Please check that the posting date, document type, document no. and amount are correct for each line.
Nav is expecting that the document to balance on a posting date. It look for balancing line sequencially so if you sort your import/journal by posting date it should post.
In continuation with the email thread, i am facing the same issue on a General Journal line. This came from LS Retail ICT process. There are only 3 lines of the same document number, date and line no is sequential.
But when i try to post, the system says that Document is out of balance by 736. check the posting date, document type etc…
Microsoft Dynamics NAV Classic
Document No. S02-MZ-P01-347593 is out of balance by 736. Please check that Posting Date, Document Type, Document No. and Amount are correct for each line.
OK
When i try to enter the same rows manually on the Gen. Jnl line with the same values, its posting correctly.
