I want to run a standard NAV Account Schedule monthly using the Job Queue. I cannot find any documentation that talks about how to make appropriate selections to run the Account Schedule. For instance the Schedule Name, Column Layout, Date filter…anything on the Options tab when you run it from the menu.
contact your solution center, and they will need to write a process (CU/Report) that sets all the parameters needed before running the account schedule.
I think it’s by default not possible…
You need software customization.
Kind Regards,
Ronald Sloep
Software Developer
Navfair Solutions.
There is documentation. As Rashed said contact your solution provider. The documentation have detailed explanation how would you setup all the parameters of Account Schedule reporting.
Here you would need customization. I have actually done this before.
